Windows Performance Monitoring Context Switches/sec ???
You can add this as a performance counter for that -
\System\Context Switches/sec
To see any performance counter you can use on a Windows platform (provided typeperf is there), go to a DOS prompt and type typeperf -qx > perfcount.txt
That will put them into a text file at the directory where you typed that command. It will be quite extensive... 15,000+ items.
