GSM modems
  • halama
    • Oct 2007
    • 9
    GSM modems
    Using somebody GSM modem for sending SMS from Zabbix?
    I want ask here for tested models and your experiences. Because is not easy order supported Siemens MC35.
    What model of GSM modem do you using???
  • evgeny elkin
    • Jul 2007
    • 52
    I'm using Nokia 2100 with gammu, and it's work fine, use search in forum
    • nelsonab
      • Sep 2006
      • 1233
      Which country? I've had no luck for SMS in the US unless you're using a email <-> sms gateway from the provider, which is useless when the network is dead.
      RHCE, author of zbxapi
      • evgeny elkin
        • Jul 2007
        • 52
        Russia. I've used Siemens C65 and it's working fine too. Phone is connected by data-cable to Zabbix server's com port. Which model are you trying to use?
