issues with monitoring files larger than 2GB
  • dle
    • Feb 2008
    • 9
    I am running zabbix 1.4.3 and having issues with monitoring files larger than 2GB on windows servers. I tried updating the agent but that didn't help.
    Any workarounds to resolve this issue? I am trying to monitor the size of exchange 2007 edb files.
    thank you
    Dat
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    What kind of issues?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • dle
      • Feb 2008
      • 9
      Zabbix reports the size as 548.39 MB or 575029248. I am using the zabbix agent command vfs.file.size[drive letter:\\full path\Regular Mailbox Database.edb]
      Windows server 2003 reports the file being 68.5GB or 73,589,473,280 bytes. The file is mounted on a lun on our network storage.
      Dat
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Please make sure that item type is set to Integer, not Float.
        Alexei Vladishev
        My Twitter
        • dle
          • Feb 2008
          • 9
          The item is set to 64-bit integer but is still not reporting the correct file size.
          • dle
            • Feb 2008
            • 9
            Anything else I could try?
            • Sasha
              Zabbix developer
              • Sep 2007
              • 60
              Thanks!
              Problem fixed in rev. 6125
              ZABBIX Developer
              Riga, Latvia
              • IvanG
                • Aug 2008
                • 12
                Hello, fixed in a new agent version or old agent version?
                Thanks!
                Ivan
                • Sasha
                  Zabbix developer
                  • Sep 2007
                  • 60
                  Hello!
                  In version 1.6.1.
                  ZABBIX Developer
                  Riga, Latvia
