proc.num in 1.4.6 not working for an item
  • forlinuxsupport
    • Oct 2005
    • 39
    Hi
    I have 2 servers running the zabbix agent.
    Server 1 has agent 1.4.1
    Server 2 has agent 1.4.6 (latest)
    I am monitoring a process called "cpdavd" - a cpanel process
    Here is the PS on Server 1
    root 31552 0.0 0.0 13060 816 ? S 2009 0:00 cpdavd - accepting connections on 2077 and 2078
    Here is the PS on Server 2
    root 2439 0.0 0.4 13884 6704 ? S Aug11 0:00 cpdavd - accepting connections on 2077 and 2078
    So you can see they are the same.
    Server 1 is monitored correctly by zabbix using this item :
    proc.num[cpdavd]
    Why does that item always return "0" on server 2 ?
    Here is the debugging log on Server 2 :
    27708:20080812:091114 Processing request.
    27708:20080812:091114 In check_security()
    27708:20080812:091114 Requested [proc.num[cpdavd]]
    27708:20080812:091114 Sending back [0]
    The actual Zabbix Server (the one doing the monitoring) is running 1.4.2.
    Could it be related to the inclusion of the long command names in zabbix 1.4.6 ?
    Cheers
    Andy
  • PascalHeraud
    • Aug 2008
    Are you running linux ?
    is there a kernel using grsec on one of the two boxes ?
    I think this is the issue because the grsec patch.
    Pascal.
    • forlinuxsupport
      • Oct 2005
      • 39
      Thanks for replying.
      The zabbix 1.4.1 box is Centos 4.4 - kernel 2.6.9-42.0.3.EL.xs0.4.0.263xenU
      The zabbix 1.4.6 box is Centos 5.2 - kernel 2.6.18-92.1.6.el5PAE
      SELinux is Disabled on Both servers
      User zabbix runs as on both servers is "zabbix"
      User apache runs as on both servers is "apache"
      I seem to be able to monitor other processes fine :
      proc.num[cpbackup]
      proc.num[mysqld]
      I think its related to the long name of the process I am monitoring.
      I could try add a "ps fax | grep -v grep | grep cpdavd" to the zabbix_agent.conf and see if that works.
