Proxy internet check
  • AudiAddict
    • Jun 2008
    • 29
    I just noticed that I posted my thread in the alpha forum, so I'm making a new posting here :
    We are using two internet connections, the 2nd one is used as a back-up for internet radio, non work related internet traffic and also as a back-up for the first line.
    I would like to create a internet/online checker for both lines, the first one wouldn't be very hard, but how would I have it check the proxy? It's using port 8080.
    Can I do a service check or ping to www.google.com with proxy host : proxy and port 8080?
    Anybody know an answer/solution to the above?
  • AudiAddict
    • Jun 2008
    • 29
    Anybody? Could I do a ping to a internet address using the proxy port on 8080?
    • teferi
      • Jul 2008
      • 93
      As far as I know Zabbix can't get through proxy. And I don't quite understand how you're going to ping smth using some port? If you're speaking about "icmpping" simple check - it's done via icmp protocol =)
      • AudiAddict
        • Jun 2008
        • 29
        You're right about that.
        Can you think of any other way of checking the status (online/offline) of our back-up internet connection (ADSL modem).
        I could ping the adsl modem, but that would only check if the modem is online, not if the actual internet connection is available on that modem.
        • teferi
          • Jul 2008
          • 93
          Try writing an external check, which'll be a script, that tries to get past proxy =) If it does print 1 otherwise - 0. It wont be hard I think.
