Cant get ANY notifications to work!
  • radamand
    • Aug 2008
    • 89
    Running Zabbix 1.4.5, i've set up a trigger as follows;
    (({server:icmpping.last(0)}=0) | ({server:icmpping.last(0)}#0))
    with an item of;
    Ping Test icmpping 30 7 7 Simple check Active
    with an action;
    TEST
    Trigger = "Test Trigger"
    Send message to User "my_username"
    Enabled
    On the Administration -> Notifications I get nothing, ever. all zero's.
    I've scoured the forums, tried everything i could think of, i just cant get it to even TRY to send a notification.
    Any ideas??
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Does the user have any medias (email, sms, jabber) attached? Look at configuration of the user.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • radamand
      • Aug 2008
      • 89
      RE: Cant get ANY notifications to work!
      Yes, user has email address configured, but zabbix doesn't even appear to TRY to send a notification anyway.
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Note that ZABBIX generates events and thus sends messages only on a trigger status change.
        Alexei Vladishev
        My Twitter
        • radamand
          • Aug 2008
          • 89
          ok..
          Interesting, I hadn't realized that. I will do some more testing then.
          Thanks!
          • radamand
            • Aug 2008
            • 89
            Update; still not working.
            Still having problems, here is what i've done;
            I set up an item to monitor the Zabbix agent on a remote server;
            Zabbix Agent Ping agent.ping 30 7 7 ZABBIX agent Active
            I set up a trigger;
            Zabbix Agent Status {adbnnjvsm02:agent.ping.last(0)}=0 Not classified Enabled
            and an action;
            Zabbix Agent Ping Failed
            Send message to Group "OSS Tools"
            Enabled
            The "OSS Tools" group has several users, all of which have an email address configured.
            I made sure that the remote agent was running and had been for several minutes (it was green on the overview page), then I logged into the remote server and killed the agent. After 15 minutes I still haven't received an email, and theAdministration -> Notifications tab still doesnt show any activity at all, even tho the overview shows the agent as down.
            am I doing something seriously wrong here??
            • tchjts1
              • May 2008
              • 1605
              So, you have the alerts set to be sent to that "group"?
              I had the same issue and am unable to send alerts to any group I have created. However, if I send that same alert to the individuals of that group, they work.
              Test it out that way.
              By the way, I am using 1.5.3
              Jeff
              • radamand
                • Aug 2008
                • 89
                no joy
                I tried changing it to send to an individual user, still no good. I checked the users media config, severity settings, etc...
                I still cannot get an action to work.
                • pawlosck
                  • Jul 2008
                  I have the same problem. Media and other things are correct, because I could sends emails few days ago, but after few hours all stop working. I have testing PC which monitoring and I unplug ethernet cord and I tried check if trigger icmping change state. Trigger changed state, but mail didn't was sent. In Monitoring->Actions nothing were appear. I am using zabbix 1.4.5 on Fedora9
                  • radamand
                    • Aug 2008
                    • 89
                    Check out my last post in this thread, might be same problem?
