noob help
  • radamand
    • Aug 2008
    • 89
    noob help
    Hello, I am just learning Zabbix and will probably be asking a few questions.
    I understand from a previous post that Zabbix only responds to a change in a trigger status, not to existing conditions.
    I set up a simple ping check with an email notification for a couple of dozen servers, the problem is, the occassional network hiccup sets off the notification when it really shouldnt.
    What I would like to do is, have it check the previous network status, and if it was down on its previous poll, and still down now, then send an email.
    But, if zabbix only responds to a change in a trigger's status, this wont work because the previous status will always be up!
    am I looking at this wrong?
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    This is exactly the case when one should take advantage of trigger functions. Instead of using simple things like:
    {host:icmpping.last(0)}=0
    do
    {host:icmpping.max(600)}=0
    The second expression will trigger only when the host was unreachable for 600 seconds, or 10 minutes.
    In other words, make trigger expressions less sensitive!
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • radamand
      • Aug 2008
      • 89
      ahhh
      ahhhh, I always wondered what that parameter was for, I had not seen it anywhere in the documentation.
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        ZABBIX Manual in PDF format is your friend, the information is there!
        Alexei Vladishev
        My Twitter
