Trigger Display Time Help
  • amaz
    • Jun 2008
    I have a trigger monitoring a weekly backup job.
    Data of this trigger only can be retrieved once a week. The problem I having is if a backup job has failed. The trigger will stay on for a week until the next backup job status data is received by Zabbix.
    How can I set the trigger to display only for 1 day?
    Many thanks!
  • exkg
    • Mar 2007
    • 718
    In the 'Expression for triggers' (ZABBIX manual) exists something that can help you:
    dayofweek - Returns day of week in range of 1 to 7. Mon – 1, Sun – 7.
    []s,
    Luciano
    Luciano Alves
    www.zabbix.com
    Brazil | México | Argentina | Colômbia | Chile
    Zabbix Performance Tuning
