postfix queue monitoring
  • fulltilt
    • Nov 2006
    • 39
    like to monitor postfix mailqueue in zabbix ...
    can i use following line in agents_conf:
    # Mailqueue
    UserParameter=postfix.queue,postqueue -p | find /var/spool/postfix/{deferred,active,maildrop}/ -type f | wc -
    and how do i set the item in zabbix and alert @ 100 mails?
    Regards
  • teferi
    • Jul 2008
    • 93
    # Mailqueue
    Regards
    I may be wrong, but you should set item simply as integer with the key postfix.queue and the trigger would look like {Somehostostfix.queue.last(0)}>100
    • fulltilt
      • Nov 2006
      • 39
      but now i have permission problem to the queue folders ... agent can not access queue folder ... is threre a way to get it working?
      # Mailqueue
      UserParameter=postfix.queue,postqueue -p | find /var/spool/postfix/deferred/*/ /var/spool/postfix/active/ /var/spool/postfix/maildrop/ | wc -l
      Debian4
      • teferi
        • Jul 2008
        • 93
        [/CODE]
        Err. add a sudo exception for zabbix user for example or add zabbix user to the postfix group. Aint that obvious?
        • fulltilt
          • Nov 2006
          • 39
          thanks teferi,
          found a solution:
          # Mailqueue
          UserParameter=postfix.queue,mailq | grep -v "Mail queue is empty" | grep -c '^[0-9A-Z]'
          this one is working :-)
          • teferi
            • Jul 2008
            • 93
            happy to help
            • richlv
              • Oct 2005
              • 3112
              thanks teferi,
              found a solution:
              # Mailqueue
              added this as an example userparameter in trunk, thanks
              • fratotec
                • May 2010
                • 12
                Queue monitoring - suggetion
                based on the info from
                I extended my userparameter to
                UserParameter=unix_mail.queue_hold,mailq | grep -v "Mail queue is empty" | egrep -c '^[0-9A-F]{11}[$!]'
                UserParameter=unix_mail.queue_active,mailq | grep -v "Mail queue is empty" | egrep -c '^[0-9A-F]{11}[*]'
                UserParameter=unix_mail.queue_deferred,mailq | grep -v "Mail queue is empty" | egrep -c '^[0-9A-F]{11}[^*]'
                which gives me the number of active, deferred and hold messages.
                As I use MailScanner with the HOLD queue options, this allows me to trigger of mails pile up in the hold queue.
                Regards.
