Heavy Cpu Load After Update To 1.5.4
  • adr.rock
    • Dec 2005
    we uprade from 1.5.1 () to 1.5.4.
    From this time we have heavy CPU load from MySQL engine:
    top - 20:26:54 up 5 min, 1 user, load average: 13.34, 7.94, 3.37
    Tasks: 185 total, 3 running, 182 sleeping, 0 stopped, 0 zombie
    Cpu0 : 95.0%us, 1.0%sy, 0.0%ni, 3.0%id, 1.0%wa, 0.0%hi, 0.0%si, 0.0%st
    Cpu1 : 97.0%us, 0.0%sy, 0.0%ni, 2.0%id, 1.0%wa, 0.0%hi, 0.0%si, 0.0%st
    Cpu2 : 93.9%us, 1.0%sy, 0.0%ni, 2.0%id, 3.0%wa, 0.0%hi, 0.0%si, 0.0%st
    Cpu3 : 91.0%us, 2.0%sy, 1.0%ni, 5.0%id, 1.0%wa, 0.0%hi, 0.0%si, 0.0%st
    Mem: 16439788k total, 2658144k used, 13781644k free, 27088k buffers
    Swap: 2031608k total, 0k used, 2031608k free, 454528k cached
    PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
    2802 mysql 15 0 17.5g 1.8g 4612 S 377 11.5 14:56.57 mysqld
    3181 zabbix 20 5 134m 3760 2308 S 1 0.0 0:00.10 zabbix_server
    3193 zabbix 21 5 134m 3748 2284 S 1 0.0 0:00.11 zabbix_server
    3195 zabbix 20 5 134m 3720 2260 S 1 0.0 0:00.11 zabbix_server
    3248 zabbix 20 5 82824 1944 524 S 1 0.0 0:00.21 zabbix_server
    3300 zabbix 20 5 82056 1992 1192 R 1 0.0 0:00.41 zabbix_server
    3337 root 15 0 12716 1136 796 R 1 0.0 0:01.70 top
    1 root 18 0 10312 680 568 S 0 0.0 0:01.69 init
    After start up Zabbix server is not possible stop them - zabbix_server daemon become zombie.
    StartDBSyncers=0 help a little (zabbix_server stop OK), performance is little bit better, but still about 80% CPU load...
    HW config:
    - QUAD CORE XEON
    - 16 GB RAM fully buffered
    - HW RAID 0 (www.areca.com.tw) with 6 SATA
    - 64bit CentOS
    before uprade CPU util to 20%...
    Any ideas?
    Thanks.
  • trikke
    • Aug 2007
    • 140
    Hi
    I had a similar problem/behaviour. It seemed that the new Server was handling the escalation differently. I deleted all the events and alarms I had in the DB, permitting the Server to "Start from Zero". This helped my getting the trafic/load down! Don't know if this is your problem though!! Just check with debug level on!
    Greets
    Patrick
    • bbrendon
      • Sep 2005
      • 873
      I would run that latest build from SVN and make sure to disable all the actions.
      I upgraded to 1.5 about 2 weeks ago and have had good success. I have it running in production now.
      Unofficial Zabbix Expert
      Blog, Corporate Site
