Monitoring Disk space
  • Retaliator
    • Sep 2008
    Hi, i tried to define a disk space usage alert on specific server, but it did not work when there were only 7 mb left on drive D.
    can any one please help ?
    Thanks,
    Retaliator
  • Retaliator
    • Sep 2008
    Anybody ???
    it's common option
    • xs-
      • Dec 2007
      • 393
      You could start by giving some info we can actualy use (server/client versions, item strings, item values, trigger strings, etc) instead of the 'it doesnt work' line.
      • Retaliator
        • Sep 2008
        okay
        I am kinda new to that but..
        someone tried to help and the options are :
        that's from items:
        snmp oid : 1.3.6.1.2.1.25.2.3.1.6.2
        that's from triggers:
        Disc C used space more then 95% {BPRDB01:disc C used space.max(100)}>19596086 Information Enabled
        • xs-
          • Dec 2007
          • 393
          Well, i doubt you want to use max(100).
          This means: Maximum value in the last 100 minutes.
          You might want to change that to last(0)
          Furthermore, what information does that OID return? Disk usage or free space in MB's or %?
          If you want to make a trigger that fire's above 95%, i advise you to use an information source that passes you disk usage in %.
          Dont know if the zabbix agent for windows can do this tho, don;t use windows much.
          • maruscya
            • Jul 2007
            • 129
            Hello guy
            I use this Activecheck
            vfs.fs.size[d:,pfree]
            it's report free space on D: drive . After i have created this tirgger
            {t_Windows:vfs.fs.size[d:,pfree]. last( 0 ) }<26
            If % of free space is lower than 26% send an email
            AndreA
            • Retaliator
              • Sep 2008
              for the last reply
              i need more info of how to add that from scratch,
              where to put what trigger, etc?
              • Retaliator
                • Sep 2008
                please help
                can any1 help me from scratch ?
