Host Name Case Sensitive ?
  • maruscya
    • Jul 2007
    • 129
    Hello Guys..
    after upgrade, some host stop sending data. After some test, the problem seem a hostname.
    homer etc # zabbix_sender -vv -z ****.**********.net -p 5001 -s mailgateway -k agent.version -o 1
    zabbix_sender [18141]: DEBUG: Answer [{
    "response":"success",
    "info":"Processed 0 Failed 1 Total 1 Seconds spent 0.000774"}]
    Info from server: "Processed 0 Failed 1 Total 1 Seconds spent 0.000774"
    sent: 1; skipped: 0; total: 1
    homer etc # zabbix_sender -vv -z ****.**********.net -p 5001 -s Mailgateway -k agent.version -o 1
    zabbix_sender [18150]: DEBUG: Answer [{
    "info":"Processed 1 Failed 0 Total 1 Seconds spent 0.006914"}]
    Info from server: "Processed 1 Failed 0 Total 1 Seconds spent 0.006914"
    In the first case zabbix_sender report 1 error...
    Could you confirm that the hostname is now case sensitive ??
    AndreA
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    I was pretty sure the host names were always case sensitive in both 1.4.x and 1.6.x
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • maruscya
      • Jul 2007
      • 129
      I don't no why, but in 1.4.5 hostname is "MailGateway" on agent side.... but on server is "mailgateway" (it is a real example !! )
      And all works fine.
      IMHO is not a real problem, but is only a question, because some hosts stop sending data after upgrade... I 'll rename all hosts asap.
      I made the same question during the training ... (4 & 5 of March) and your answer is "....mmmm .... i think ! .."
      anyway... thank for your good job!
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Mmmmm ... I think the answer depends on how database engine handles operator '='.
        Alexei Vladishev
        My Twitter
        • ad@kbc-clearing.com
          • Sep 2005
          • 77
          We use MYSQL/InnoDB and migrated recently from 1.4.2 to 1.6
          I don't think this issue is caused by the DBengine; this has not changed during the migration.
          In 1.4.2 we had no problems.
          In 1.6 we found, that not only hostname but also key is case-sensitive.
          Renaming our hosts to all lowercase is not an option.
          • maruscya
            • Jul 2007
            • 129
            I'm starting migration hosts from "mixed case" to "lower case" .
            This is not a good solution, but imho is it the only way !
            AndreA
              • Sep 2005
              • 77
              We just renamed all hosts to lowercase (sql update query) -> no more problems.
              Not happy with that, but i'm afraid the only option.
              • Alexei
                Founder, CEO
                • Sep 2004
                • 5654
                Case sensitivity depends on settings of your database only. I do not believe that upgrade from 1.4.x to 1.6.x affected this in any way. Blame your database or database admin.
                Alexei Vladishev
                My Twitter
                • Calimero
                  • Nov 2006
                  • 481
                  I have to disagree.
                  if (0 == strcmp(item.host_name, values[i].host_name) && 0 == strcmp(item.key_orig, values[i].key))
                  That's line 216 of trapper.c (v1.6.1)
                  And that means that both hostname and key indeed are case sensitive, regardless of database engine (which could also be case-sensitive of course).
