Number of process (W32Agent)
  • Zoltan
    • Jul 2005
    My goal is to know how many process with the same name are running
    ex: If i got 3 notepad opens --> it returns the value 3
    I think i have to use the proc_info parameter but i don't see how.
    Can you help me please.
    Thank you
  • mconigliaro
    • Jun 2005
    • 116
    use proc_cnt[<nameofservice>]
    • Zoltan
      • Jul 2005
      Thank you very much, i didn't know proc_cnt exist
      Thanks for your help
      • mary nancy
        • Jul 2005
        • 125
        Proc.num or proc_cnt parameters dont work on windows. I would klike to know what is the parameter that is used to monitor the number of running process in windows.
        Nancy
        • mary nancy
          • Jul 2005
          • 125
          proc.num[process name] works fine for me
          eg:
          Description:Monitoring CMD process
          Type:zabbix agent
          Keyroc.num[cmd.exe]
          Type of information:Numeric (interger 64bit)
