1.5.4 to 1.6
  • Lufa
    • Jul 2007
    • 46
    1.5.4 to 1.6
    Hi! How can I upgrade database structure to the latest 1.6 state? I was using 1.5b nightly build from 25.09.08.
    Thank you.
  • xs-
    • Dec 2007
    • 393
    AFAIK you can either follow 2 paths.
    1.
    - make a schema only mysqldump from your 1.5
    - Create a new db (temp), import create sql from 1.4.x and apply the 1.6 patch
    - manually compare the differences and fix the database
    2.
    - make full dump (backup) of 1.5 + data only dump
    - drop database / create new database
    - import create sql from 1.4.x + apply 1.6 patch
    - import data only dump
    - when error occurs, fix error, rinse , repeat
    I think option 1 is preferable
    • Lufa
      • Jul 2007
      • 46
      Thank you! I'll try!
      • fmtaylor2
        • May 2006
        • 66
        please
        Tell me there is a better (aka easier) way to do this. I was kinda expecting a db upgrade for those of us who went the 1.5 route as well as for those who stayed with 1.4. Any hopes of this happening??
        • xs-
          • Dec 2007
          • 393
          1.5 is a development tree.
          Its not uncommon that within a development tree the schema changes are non-sequential.
          Thats why stable->stable upgrades are guaranteed, and development->stable are not.
          • Lufa
            • Jul 2007
            • 46
            I just used the db patch from 1.4 to 1.6, commenting any lines which caused an SQL "table/field already exist" errors.
            • sergio.cricca
              • Mar 2008
              • 43
              i did the way i posted on http://www.zabbix.org/forum/showpost...94&postcount=6 thread and worked for 1.5.3 -> 1.6.1
              I think it should work the same way from 1.5.x to 1.6.x
              bye
