UserParameter=mysql not working with 1.6
  • clubbing80s
    • Sep 2005
    • 109
    Hi
    I have installed zabbix 1.6 on my server and created a template for mysql items
    except that the mysql items report back as "not supported" ..
    The Items are configured as per the manual ..
    so what could I have missed
    all the commands can be run as the zabbix user
    zabbix_agentd.conf
    UserParameter=mysql.ping,mysqladmin -uroot ping|grep alive|wc -l
    UserParameter=mysql.uptime,mysqladmin -uroot status|cut -f2 -d":"|cut -f1 -d"T"
    UserParameter=mysql.threads,mysqladmin -uroot status|cut -f3 -d":"|cut -f1 -d"Q"
    UserParameter=mysql.questions,mysqladmin -uroot status|cut -f4 -d":"|cut -f1 -d"S"
    UserParameter=mysql.slowqueries,mysqladmin -uroot status|cut -f5 -d":"|cut -f1 -d"O"
    UserParameter=mysql.qps,mysqladmin -uroot status|cut -f9 -d":"
    UserParameter=mysql.version,mysql -V
  • sybex
    • Aug 2008
    • 29
    Hi, ..
    i think the Items in the frontend are wrong configured.
    They have to be like this:
    mysql.ping
    in my zabbix 1.6 they was like this: mysql[ping]
    check this ...
    after the change in the frontend the items are working fine in my zabbix.
    • clubbing80s
      • Sep 2005
      • 109
      this is my item .... cant see a reason for it not working ??
      Description MySQL is alive
      Type ZABBIX Agent
      Key mysql[ping]
      Type of information numeric (float)
      Units
      Use multiplier dont use
      Update interval (in sec) 60
      Flexible intervals (sec) No flexible intervals
      New flexible interval Delay 50 Period 1-7,00:00-23:59
      Keep history (in days) 90
      Keep trends (in days) 365
      Status Active
      Store value As is
      • sybex
        • Aug 2008
        • 29
        Hi, ...
        try to change the Key from:
        mysql[ping]
        to
        mysql.ping
        because that [] is meaning a variable value and needs in UserParameter a value like this mysql[*]
        and only a point mysql.ping means directly a function, so you have configure UserParameter like this mysql.ping
        someone have to correct me if i'm wrong ...
        • Kees Jan Koster
          • Oct 2007
          • 83
          Well, I ran into a similar issue. I could not even get trivial user parameters to work, not even when testing locally (i.e. no server involved).
          Here is the bug report.
          Kees Jan
          • linuxdan
            • Sep 2008
            • 18
            Same issue.
            I'm having the same issue as Kees. Does anyone know of a good way to test user parameters? I'm running 1.6.1 on RHEL4. Oh and linking to a bug report that requires a login isn't all that helpful.
            Kees Jan
            • tchjts1
              • May 2008
              • 1605
              *bump*
              Anyone getting their mysql userparameters to work in 1.6.1?
              I have them configured the same in the frontend as in the userparameter statements, but no go.
              • tchjts1
                • May 2008
                • 1605
                Anyone? Beuhler...Beuhler...
                • Fatima R R Tonon
                  • Oct 2004
                  • 29
                  Problems with UserParameter
                  Yes, I had problems with the multiple parameters.
                  Zabbix Configuration file:
                  UserParameter=tot[*],/etc/zabbix/scripts/processa_quota.sh $1 $2 $3 $4
                  Implementation of command using shell
                  [root@corp]# /usr/local/zabbix-1.6.1/bin/zabbix_agentd -t tot[0,0,100,pr.ex.br]
                  tot [m|ZBX_NOTSUPPORTED]
                  This script worked in version 1.4.6 !!!
                  • bogdar
                    • Jan 2009
                    • 33
                    I uncomment just an example line:
                    UserParameter=system.test,who|wc -l
                    and executed test:
                    ~# zabbix_agentd -t system.test
                    system.test [m|ZBX_NOTSUPPORTED]
                    ~# grep zabbix /etc/passwd
                    zabbix:x:1004:1004:Zabbix:/dev/null:/dev/null
                    • richlv
                      • Oct 2005
                      • 3112
                      see http://www.zabbix.com/forum/showthread.php?p=41852 for my attempts at finding out "wtf".
