Strange SCREENS problem
  • shaihi
    • Oct 2004
    • 17
    I set a screen of two network maps about 2 weeks ago. Everything was fine until yesterday when the lower map wouldn't respond to mouse clicks ( for example when I click on a server ). The strange thing is when I open the network map itself everything is fine. I tried to switch between the upper and lower maps, and the lower map ( the new one ) still does not respond.
    I also tried to setup a new screen with the same maps and the same problem occured again.
    Any idea?
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Does it happen always when you have more than one map in a screen? I think the problem existed before.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • shaihi
      • Oct 2004
      • 17
      Well yes you're right it always happnes when I put more than one map, although, if I put the same map twice it works well.
      Another thing which I noticed is that the "inactive" map always has "hidden" links which are connected to the machines which appear in the active one.
      Did you fix it in the new version?
      Thanks,
      Shai
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Yes, it will be fixed. Actually the fix is very trivial. I don't have access to the sources currently, just guessing that all maps have the same name for corresponding image maps (html ISMAP).
        They must be unique per each map.
        Alexei Vladishev
        My Twitter
        • shaihi
          • Oct 2004
          • 17
          Thanks for the quick response.
          Shai
