Any way to setup triggers for a certain time period?
  • stever
    • Jun 2006
    • 36
    I'm wondering if there is a way to setup triggers in zabbix to be dependent on the time period. I know this can be done with actions, but I'm wondering if there's any way to do so for a trigger. And if not, I would like to make that a feature request.
    Right now, I have the following setup:
    Triggers:
    - one trigger that triggers if we have no messages received in the last hour, i.e. messagerate.max(3600)<1
    - one trigger that triggers if we have no messages received in the last 12 hrs
    Actions:
    - alert on messages received in last hour trigger, Time period in "2-6,06:00-17:59"
    - alert on messages received in 12 hrs trigger, no time period restriction
    Currently, this covers what I'm going for, basically alerting only during weekday, working hours for the more sensitive trigger. However, it gets difficult to trace down these events using the event history, as throughout the off hours, the sensitive triggers are flapping constantly. Since we have 11 hosts based on this template, my event history is full of this sensitive trigger going on/off during off hours, and its tough to track down any real occurrences.
    Any ideas how to get around this? I'm thinking about writing a custom user-monitored value, and associated trigger to trigger during off hours. Then, by adding a dependency to these triggers, they won't trigger throughout the night.
    However, all this would be so much easier and more powerful if I were able to specify a trigger with a validity time period.
    ps - I am running zabbix 1.4.6, and have also tried this on my 1.6 test machine.
  • alixen
    • Apr 2006
    • 474
    There is a time function that can be used for trigger evaluation.
    I have not used it yet but, according to Zabbix user manual, you could write something like:
    {host: param.time(0)} >= 06000 & {host: param.time(0)} < 180000
    Hope this helps
    Alixen
    http://www.alixen.fr/zabbix.html
    • stever
      • Jun 2006
      • 36
      Great stuff, I just tested and it worked. This is the exact trigger expression I used, I figured icmpping was the easiest item to use the time expression on. I guess you could use the other time based items as well, i.e. dayofweek(), date(), now() as well.
      {Template_VZ:icmpping. time( 0 ) }>104600 & {Template_VZ:icmpping. time( 0 ) }<104800
      • sevan
        • Aug 2011
        • 11
        trigger time
        would you please explain more about the numbers and method in for the following expression:
        In other word please explain the expression in words.
        • harmonica
          • Jan 2009
          • 251
          Means that the trigger is activated only from 10h: 46m: 00s until 10h: 48m: 00s
          • sevan
            • Aug 2011
            • 11
            timer
            104600 means 10:46:00 or 18:46:00?
            • harmonica
              • Jan 2009
              • 251
              Sorry, my mistake.
              Yes, 10h: 46m: 00s until 10h: 48m: 00s
              • sevan
                • Aug 2011
                • 11
                zabbix trigger timer config
                I wanted to setup a trigger to be active 24 hours except the period of time for one hour between 2Am to 3AM, is this a correct expression:
                {server.01:ifHCOutOctets.10020.time(0)}>000000&{se rver.01:ifHCOutOctets.10020.time(0)}<020000&{serve r.01:ifHCOutOctets.10020.time(0)}>030001&{server.0 1:ifHCOutOctets.10020.time(0)}<240000
                please advise,
                • delatbabel
                  • Aug 2011
                  please advise,
                  No, that doesn't look right to me.
                  Try this:
                  ({server.01:ifHCOutOctets.10020.time(0)}<020000|{s erver.01:ifHCOutOctets.10020.time(0)}>030001)
                  A similar trigger seems to work for me, getting alerted on CPU load except between 2am and 6am (backup window when the backup program can drive the CPU up):
                  {Template_Linux:system.cpu.load[,avg1].last(0)}>5&({Template_Linux:system.cpu.load[,avg1].time(0)}<020000|{Template_Linux:system.cpu.load[,avg1].time(0)}>060000)
