Currently I am trying to use the following SNMP IOD after reading some posts regarding Dyanmic indexes. There was one specific post that suggested that the followign should work.
ifInOctets[index,ifDescr,$1]
Unfortunately this has been failing with the following error:
Cannot find index [ifDescr] of the OID [ifInOctets[index,ifDescr,$1]]
I have also tried using (64 bit counters)
ifHCInOCtets[index,ifDescr,$1]
With the following key:
ifInOctets.[GigabitEthernet1/0/1]
I recieve the same error as above
I have also used the OID's for all the snmp variables with no luck :/
The OID and name values all return valid data via snmpwalk.
I am using zabbix 1.6.
Any pointers, example? Can someone post a item breakdown if they have a functional item with snmp dyanmic indexes?
Thanks,
Sono
Thanks,
Sono
