Help needed with configuring repeated e-mails
  • v.rusinov
    • Apr 2008
    • 22
    Hi.
    I need to repeat e-mails every x minutes when something is down.
    Here is how I configured it.
    But it send only one message when trigger goes down, and one message when trigger does up.
    What I'm doing wrong?
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    I would recommend:
    - add condition "Trigger value = Problem"
    - enable recovery message (only one recovery message will be sent)
    For indefinite repeats, select number of steps From 1 To 0 and set Period to a reasonable number of seconds, say 600 seconds (10 minutes).
    I hope this helps.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • v.rusinov
      • Apr 2008
      • 22
      Thank you.
      Howewer, I've found another way: Event generation = with multiple TRUE events for each item I need.
