Reload zabbix_agentd configuration
  • rts
    • May 2007
    • 54
    Can a signal be sent to zabbix_agentd to cause it to reload the configuration? At present, if I change the config file, I have to killall zabbix_agentd, then wait for no zabbix processes to be running, then restart it. Is there a better way?
  • tazzu
    • Nov 2006
    • 26
    I think you can't change the configuration while runetime. As you said you have to stop the agent and restart.
    Edit:
    The better way to kill the processes is:
    /etc/init.d/zabbix-agent stop
    • Jun.Liu
      • Apr 2007
      • 91
      I'm using the zabbix1.6.1 but I can't find the zabbix-agent at directory /etc/init.d/.
      but it seems ok that just issue the command 'zabbix_agantd' and press ENTER!
      • tighep
        • Dec 2007
        • 124
        While you do need to bounce the agent, it is possible to automate that task. I created a trigger that watches the config file, when that changes a remote command runs a script that calls the at command to issue my restart. This has been working for me for about 6 months now.
        • tchjts1
          • May 2008
          • 1605
          After you compiled the code, did you do this step? (From /home/zabbix/zabbix-1.6.1)
          sudo cp misc/init.d/debian/zabbix-server /etc/init.d/zabbix-server
          sudo cp misc/init.d/debian/zabbix-agent /etc/init.d/zabbix-agent
          And after you complete that, also do this:
          In zabbix-server and zabbix-agent
          Look for the following line:
          DAEMON=/home/zabbix/bin/${NAME}
          and replace it with:
          DAEMON=/usr/sbin/${NAME}
          After that you should be able to use sudo /etc/init.d/zabbix-agent stop
          And if you want Zabbix to come up when the machine reboots, do this:
          set the correct permissions and set ZABBIX to start when the machine boots:
          sudo chmod 755 /etc/init.d/zabbix-server
          sudo update-rc.d zabbix-server defaults
          sudo chmod 755 /etc/init.d/zabbix-agent
          sudo update-rc.d zabbix-agent defaults
          • Jun.Liu
            • Apr 2007
            • 91
            To tchjts1,
            the Zabbix was installed by someone else.
            It work after done the actions you post. many thanks your detail instructions!
            • tchjts1
              • May 2008
              • 1605
              To tchjts1,
              You're very welcome. Glad it worked out for you.
              Jeff
              • bashman
                • Dec 2009
                • 432
                To add zabbix_agentd as a RH service:
                Lookout for zabbix_agentd_ctl
                cp -v zabbix_agentd_ctl /etc/init.d
                chmod -v 755 /home/etc/init.d/zabbix_agentd_ctl
                chkconfig --add zabbix_agentd_ctl
                chkconfig --level 345 zabbix_agentd_ctl on
                chkconfig --list
                /etc/init.d/zabbix_agentd_ctl start
                /etc/init.d/zabbix_agentd_ctl help
                To remove zabbix_agentd from a RH service:
                /etc/init.d/zabbix_agentd_ctl stop
                chkconfig --level 345 zabbix_agentd_ctl off
                chkconfig --del zabbix_agentd_ctl
                rm -v /etc/init.d/zabbix_agentd_ctl
                978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15
