Change Link in [Networks Maps]
  • daniel_psx
    • Jul 2005
    • 13
    Hi my friends
    I have a big big problem . I need change the Hyperlink generated by
    Zabbix in the Network Maps . For example:
    Press in the icon Router X.X.X.X show the triggers by default
    i need change for show screeen asociated to this router
    i try to edit the php files but see thats generate a temporal file map.php
    Daniel_psx
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Originally posted by daniel_psx
    Hi my friends
    Daniel_psx
    You may specify any URL for the router icon. So, when you click on the icon you'll be automatically transferred to the specified location.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • daniel_psx
      • Jul 2005
      • 13
      Thank for help but i use version 1.0, and cannot find the option? Any tip?
      other question .... is necessary touch the code for this problem.
      My idea is :
      router --(press icon and then show)---> servers + router (asociated to the routers)
