1.6 and AIX CPU stats
  • tighep
    • Dec 2007
    • 124
    I know hoyt created a patch for 1.4 that would enable some of the unsupported items for AIX, including CPU utilization. I just loaded 1.6 onto a test system, and I am not getting information for the CPU stats. When I attempt to run it from the command line, I see:
    ./zabbix_agentd -t system.cpu.util[,idle,avg1]
    system.cpu.util[,idle,avg1] [m|Collector is not started!]
    I did a quick search and I don't see anything new regarding these items. If they are not working in 1.6, I guess I'll have to dig through hoyt's patch to see if I can figure out how to make it work. Thank you to all.
  • tighep
    • Dec 2007
    • 124
    A little nudge back to the top. Has anyone tried running the 1.4 patch into the 1.6 code? I'm thinking about attempting that tomorrow and wanted to know if anyone else has had any luck.
