Zabbix Requirements
  • nastweb
    • Oct 2008
    • 9
    Zabbix Requirements
    Dear All,
    Kindly please make me sure that my configuration are appropriate for monitoring 500 client (specialy about innodb_data_file_path).
    Here is my configuration :
    Intel processor Core 2 Duo.
    Ubuntu 8.04 64 bit
    2 GB RAM
    40 GB Hardisk
    I Installed xampp-linux-1.6.7.tar.gz (PHP 5.2.6, apache 2.2, MYSQL 5)
    my.cnf configuration:
    # Comment the following if you are using InnoDB tables
    # skip-innodb
    innodb_data_home_dir = /opt/lampp/var/mysql/
    innodb_data_file_path = ibdata1:10M:autoextend
    innodb_log_group_home_dir = /opt/lampp/var/mysql/
    innodb_log_arch_dir = /opt/lampp/var/mysql/
    # You can set .._buffer_pool_size up to 50 - 80 %
    # of RAM but beware of setting memory usage too high
    innodb_buffer_pool_size = 1G
    innodb_additional_mem_pool_size = 20M
    # Set .._log_file_size to 25 % of buffer pool size
    innodb_log_file_size = 250M
    innodb_log_buffer_size = 8M
    innodb_flush_log_at_trx_commit = 1
    innodb_lock_wait_timeout = 50
    Thanks,
    NS
