SNMP interface values incorrect?
  • eger
    • Nov 2006
    • 95
    I am not sure why. But my interface values are incorrect when testing with the Dell 5324 template.
    I have put in the SNMPv2 community for the switches I am testing into the template to get it working. It looks to be grabbing data correctly. However it shows interface 2 as:
    ifInOctets.2 03 Nov 15:47:52 1.50 Mbps
    I know that the port is pushing about 100 mbit/s into the port based on the server and another polling software.
    Is this a known issue or have I missed a step in setup?
  • akatsuki
    • Nov 2008
    • 10
    hi
    I think you should check ifOutOctets.
    • eger
      • Nov 2006
      • 95
      Both are incorrect and are not even close to the real throughput of the port.
      • akatsuki
        • Nov 2008
        • 10
        As far as I checked the default Dell 5324 template on Zabbix 1.6, A value 'Custom multiplier' must be 8 not 0.125.
        Because normally ifXOctets is a counter of the total number of octets, or normaly bytes, so if we need bps we have to convert this bytes into bits with multiplier 8 (and Delta).
        Is it default template's mistake?
        • MrKen
          • Oct 2008
          • 652
          Beware of ALL Templates
          Akatsuki is correct. Change 'Custom Multiplier' to 8. You may also need to clean the history for that item or host, otherwise your graphs may be distorted.
          IMHO, most of the templates have errors. Look at the templates for snmpv1, snmpv2c, C3750-48TS, Cisco-2960, just for starters. They look to me to be measuring In/OutOctets incorrectly.
          Most, if not all, templates are user-made. Whether anyone at the Zabbix team actually takes the time to check them or apply them for testing, I don't know.
          Could be a case of Caveat emptor!
          If anyone is using any of the abovementioned templates, you must have some pretty strange graphs.
          • troffasky
            • Jul 2008
            • 639
            I've often wondered who would be interested in a graph of an interface that's a) in bytes per second and b) not being stored as a delta, so is nonsense anyway.
            • eger
              • Nov 2006
              • 95
              Makes sense. I will copy these and re-make them to tailor to my own devices then.
