Send SMS in 1.6 doesn't work
  • unizabbix
    • Jul 2008
    • 28
    Hi all,
    after upgraded Zabbix from 1.4.5 to 1.6 my pocket gsm modem doesn't work anymore.
    With 1.4.5 it works very well, but now it returns
    Expected [OK] received [AT+CMEE=2ERROR]
    and in the log
    In send_sms()
    Write to GSM modem [^[]
    10465:20081104:162620 Write to GSM modem [AT+CMEE=2^M]
    10465:20081104:162620 Read from GSM modem [^[AT+CMEE=2^MERROR^M]
    10465:20081104:162620 Write to GSM modem [^M^[^Z]
    10465:20081104:162620 Read from GSM modem []
    10465:20081104:162620 End of send_sms() [FAIL]
    I know that my gsm modem is not tested with zabbix, but how it possibile that upgrading it doesn't work?
    The source code of send_sms seems to be the same....
    Help me, thanks!
    P.S. With minicom it works.
  • unizabbix
    • Jul 2008
    • 28
    Does someone knows if is a Zabbix or modem problem?
    • knoppkius
      • Sep 2008
      It may sound strange, but you can try this:
      In /usr/local/src/zabbix-x.x.x/src/libs/zbxsms/sms.c (line 183 in zabbix-1.6.1) change
      /* 1 */ {"AT+CMEE=2\r" , "OK" , 5 }, /* verbose error values */
      into:
      /* 1 */ {"AT+CMEE=2\r" , "ERROR" , 5 }, /* verbose error values */
      Exit and "make && make install".
      • unizabbix
        • Jul 2008
        • 28
        into:
        Now i have this error :
        Expected [ERROR] received [ RING RING RING RING RING RING RING RING RING RING RING RING RING RING RING RING RIN
