I did the upgrade but my /usr/local/zabbix/sbin folder is empty
what i dit
-downloaded and extracted
-updated the database
-./configure --prefix=/usr --with-mysql --with-net-snmp --enable-server --enable-agent
-make install
-copied the frontend to the apache folders
-ran the upgrade at the webserver, it ran successfully
problem is that my zabbix_server proccess cannot start cause the file are not there
somebody got a clue?
note: I run zabbix on Debian x68 40r3, mysql, 1.4.6 worked like charm
what i dit
-make install
