1.6.0 Bandwidth Sum
  • scott_stantive
    • Oct 2008
    1.6.0 Bandwidth Sum
    Is it possible to create a graph of the total bandwidth used for a given period. I know I can create a graph of bandwidth usage using the simple delta but I'd like to sum up the values over a given range to determine the bandwidth usage. There's a couple of entries in the forum about this but they were from 2006.
    Thanks in advance for any help!
    Scott
  • mainframe
    • Dec 2007
    Looking also for that solution as it would be nice to use zabbix also for ip based bandwidth accounting. Maybe its possible with custom commands run on agent?
    • Tenzer
      • Nov 2007
      • 316
      Currently there are no way of calculating items in Zabbix, but if you just want the data on a graph you could stack a graph with the bandwidth items you want to include.
