zabbix sender multiple items / direct connection
  • btoovey
    • Sep 2007
    • 16
    I cannot find the documentation to use zabbix sender to send multiple pieces of data. Also can the outside script sending data control the timestamp of the data being sent to the trapper? I want to be able to send data that represents changes in state of a system but which might occur at non specific time periods, and I would ike it accurate to the second. Is there any documentation for building a direct connection to the trapper and relaying data via this method? Maybe an example via telnet?
    Thanks,
    Brian
