zabbix_sender error code
  • ngarnier
    • Mar 2008
    • 21
    When I send a value with zabbix_sender, I get a "0" error code (echo $?) when "failed" is 0 or 1, no difference.
    How can I get the error code when I use zabbix_sender in a shell script with a for loop and 800 host ?
    Thanks.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    It seems you are using zabbix_sender in a highly inefficient way. The binary supports sending of multiple values from a file. In this case, only one execution of the sender is required.
    I think that currently the sender always returns '0'.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • ngarnier
      • Mar 2008
      • 21
      It's not the problem, if I have 800 hosts in a file, how can I know if I have an error if zabbix_sender always ends with value 0 ?
      Mostly in a shell script ?
      Example :
      [root@diane ~]# /opt/zabbix/sbin/zabbix_sender -i outage_snd.txt
      sent: 488; failed: 7; total: 495
      [root@diane ~]# echo $?
      0
      How can I know which "sent" has failed ?
      No way to know if it's OK or not ?
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        I understand. Well, the only way is to parse output of the sender, which is quite simple task.
        Alexei Vladishev
        My Twitter
