Hi, all
I plan to check system clock difference between target and zabbix server,
and set {target_host:system.localtime.fuzzytime(60)}=0 to fire the trigger.
I was not careful about server and agent host, and miss to picked up target and server which is running on same H/W, but different VM.
The things I encounted was the update on all items has stopped when I changed time at server manually.
After I correct the time at the target, all items just started to be updated.
Does zabbix server check local timestamp and stop item update if there is any difference?
Thanks in advance for any suggestion / help.
My environment:
ZABBIX server 1.6.1 running on Cent OS 5.2
ZABBIX agent 1.4.5 running on Cent OS 5.2
My environment:
