SSH tunneled Zabbix Proxy
  • Fran
    • Dec 2008
    Hi!
    I'm trying to set up a Zabbix Proxy to record data from several servers placed behind a very restrictive (and completely out of my control) firewall. There's only one port open for incoming connections: 22. Not a single usable one for outgoing.
    To put it in perspective: I can ssh to the proxy server (Dido) from my Zabbix server (Aeneas). That's all.
    So, I've created a reverse ssh tunnel: all connections to Dido:10052 are actually redirected to Aeneas:10051. AFAIK, you need nothing more to make a proxy work.
    Dido is configured to communicate with localhost:10052. I can telnet to this port and Aeneas answers, so I'm discarding tunnel-related issues here. Other agents are configured to use Dido:10051 as their server. In the GUI I've added Dido as a proxy and configured the monitored servers accordingly. And it doesn't work:
    - The proxy log shows a different message when the tunnel opens:
     4802:20081211:153901 Unable connect to the server [localhost]:10052 [Cannot connect to [localhost:10052] [Connection refused]]
      4802:20081211:154001 Heartbeat message sendig failed
    I don't know what this failure means, but Aeneas doesn't has any reference to Dido in its logs.
    - Even though the servers are configured as being proxy-monitored, Aeneas tries to connect to their port 10050 once and again (and fails, obviously).
    - No data is being collected in the proxy.
    I'm really stuck with this.
  • Niels
    • May 2007
    • 239
    Please show us your actual ssh command.
    • Fran
      • Dec 2008
      OpenSSH is used at both ends:
      ssh -f -N -R 10052:aeneas:10051 dido
      • tbrimson
        • Oct 2008
        we'll be doing a workaround at our company to get around a similiar issue.
        We'll be setting up a dedicated box that will maintain an SSH tunnel to our office over port 80(the only port we have available).
        We'll configure the zabbix proxy to send all of it's information along that tunnel to our HQ where it can be routed to the Zabbix server.
        Don't know if that helps or will work in your circumstances but just a thought
