How to change the default SLA
  • RattleS
    • Oct 2008
    Hi everybody,
    I want my Zabbix to display the last months SLA at the "IT-Services" Page.
    I know that there is no Button or something which can be switched to display a other Time Period.
    Ive been reading the Forum and found a Post where someone configured some Files for displaying a other Time Period that the 7 days.
    Can someone please tell me where do i have to change some Files, so that 30 Days are displayed instead of 7? That would really help me out.
    I know that this is not supported in any way by Zabbix, but it would fit for my Needs!
    Thank you for your Replys =)
    RattleS
  • tighep
    • Dec 2007
    • 124
    Sorry for the slow response, it's rather simple to change actually. In your srv_status.php file look at line 167, it should read " $period_start = $now=7*24*3600 " Change the 7 to 30 and it will give you a 30 day SLA. Make sure to update the locale file located in include/locales/?????.inc.php and modify the S_SLA_LAST_7_DAYS variable to reflect the change to 30 days.
    • RattleS
      • Oct 2008
      Thank you very much for your help.
      Will this work directly from the Point when i change the srv_status.php file, so that it reflects even the Data collected before?
      Or do I have to wait until the 30 Days are complete from the Point of changing the srv_status.php File?
      I am asking, because it keeps telling me the same SLA Percentage before and after the Edit of the srv_status.php
      I hope you understand what i mean and sorry for my English.
      Greets,
      RattleS
