Serious Problem: EMAIL being FLOODED with Alerts
  • low10sws6
    • Oct 2008
    • 44
    it doesn't matter if i disable the action or remove the item and trigger or everything related to the hosts causing the problem.
    I made a simple add of an item with a trigger
    item
    description - SNMP DOWN
    oid = .1.3.6.1.2.1.1.1.0
    key = sysDescr.0
    type = text
    trigger
    {SNMP DOWN Checks:sysDescr.0.nodata(300)}=1
    basically the trigger returned a value=problem
    in this case an action set to a trigger value=problem
    which then sends an email and usually once cleared value=OK
    no more emails.
    unfortunately the problem for the item is still in it's down state. so i need to fix the problem with the device, and mean while needing to stop the emails that come every 2mins
    i disabled the action sending the email, disabled the item and the trigger. and i'm still getting emails.
    how do i remove the events and stop the emails with out having to bring the device back up in production and make it work to trigger the item/trigger to a OK value.
  • low10sws6
    • Oct 2008
    • 44
    I believe the event status of the trigger value=unknown
