Create template from host
  • gedp
    • May 2006
    • 47
    As a test for 1.6, we created a host with a lot of items important to us. We could of course clone this host, but it would be nice if we could create a template with the items, triggers, graphs, screen of this one host. Is this possible?
    Thanks,
    Geert
  • mlange
    • Sep 2008
    • 78
    IMHO there is not much difference how hosts and templates are handled. I also created a new host with my items and triggers in the first step. Then exported it via xml and just replaced the hostname with the {HOSTNAME} macro. You can import the template then and assign it to your hosts. Your items and triggers should now be shown in grey color meaning that they are used from the template.
    • gedp
      • May 2006
      • 47
      mlange,
      Thanks for this. Was able to create a template.
      Don't know if this has something to do with it, but in the .xml, I changed the status to 3 (I did an export from an existing template to check).
      • MrKen
        • Oct 2008
        • 652
        Why not just go to Configuration --> Hosts --> Templates --> Create Template
        then, copy the items, triggers, and graphs to the template.
        Maybe you can try this next time.
        MrKen
        • gedp
          • May 2006
          • 47
          This is indeed a simpler and good solution. Thanks.
