Custom Reports
  • zibbax
    • Nov 2008
    • 11
    Custom Reports
    Is there a guide on creating custom reports? I made a copy of report5.php and modified the sql query, and updated the db fields the loop looked for to populate the table data, however whenever I try to display the page I get an error:
    ERROR: No permissions!
    This is being done by the admin user (Super Administrator).
    Here is the code snippet.
    $available_hosts = get_accessible_hosts_by_user($USER_DETAILS,PERM_RE AD_ONLY,PERM_RES_IDS_ARRAY);
    $sql = "select * from hosts where dns not like 'mydomain.com' and host not like 'Template'";
    $result=DBselect($sql, 100);
    val_dump ($result);
    while($row=DBfetch($result)){
    if(!check_right_on_trigger_by_triggerid(null, $row['hostid'], $available_hosts))
    continue;
    $table->addRow(array(
    get_node_name_by_elid($row['hostid']),
    $row["host"],
    expand_trigger_description_by_data($row),
    new CCol(get_severity_description($row["dns"]),get_severity_style($row["dns"])),
    $row["useip"],
    $table->show();
  • zibbax
    • Nov 2008
    • 11
    I was able to get this going. The page_header.php needs an array value for this group or it won't work.
    Hooray reverse engineering code!
    Perhaps when I get better at this I'll make up a dev cookbook for customizations.
    Now if I could only get SNMP working.
