What are "Applications" supposed to do?
  • Vide
    • Sep 2007
    • 11
    Hi
    I've lloked carefully through the 1.6 manual but I cannot find out (a part from an obvious description) what "Applications", in the "Hosts" tab, are supposed to do.
    Any idea?
  • Calimero
    • Nov 2006
    • 481
    Application don't do much.
    They just allow you to group items.
    You could create a "Memory" application, and attach all memory related items to it. Same with a "MySQL" Application. Then when you go to Monitoring > Latest data, items will be grouped by application (and you can show/hide applications if you're only interested in MySQL items at that moment, for example).
    Application can also be a filter when defining Actions (alerts). You could create an Action with filter "Application = MySQL" to notify your DBA. As only items are linked to Applications, I assume that zabbix evaluates what Applications items are in, when a trigger goes on.
    • Vide
      • Sep 2007
      • 11
      Ok thanks for the clarification... maybe the name should be changed to something more appropiate or descriptive. Personally I found "Application" a bit misleading (something like Categories perhaps?)
