Delay Queues (again)
  • mlange
    • Sep 2008
    • 78
    When setting up a new server i am facing one annoying issue. At a certain time the delay queues are filled wit a lot of items. This happens when I activate a new host which is connected to several templates. Activating it leads (at once) to ~1500 delayed items in the queue. All these items are zabbix agent checks (jmx checks for Zapcat). I cannot figure out why. It can't be a load or network related problem, this looks ok. The queue is not decreasing.
    Before activating the new host (no item in the queue):
    Required server performance, new values per second 38.1006
    After activating:
    Required server performance, new values per second 56.645
    I also have another server which has a value of ~88 and no problems.
    Looking at the "details" a lot of queues items have a "next check" of "01.01.1970 01:00:00". Is that correct? This leads to false alerts: triggers which rely on nodata(t) fail because they seem to be initialized with "01.01.1970 01:00:00" and evaluate to "true" at once...this is ugly.
    Is there any way to track down why the items are queued?
    Thanks,
    Marek
  • scott.stephen
    • May 2009
    Any answer to this question ? I have the same problem.
