Trigger on SNMP timeout?
  • naushit
    • Mar 2008
    • 9
    I just want to create a trigger when SNMP check fails!
    For example Host:uptime (Timeout while connecting to [20x.7x.13x.xx:161]
    is there anyway to create equivalent of
    {zabbix.com:status.last(0)} = 2?
    I can not create create "status" , item because SNMP device does not have zabbix agent embedded inside.
    Please help...any pointers are appreciated
    Thanks in advance.
  • Calimero
    • Nov 2006
    • 481
    Use the nodata() function.
    {MY_SNMP_DEVICE:ifInOctets.1.01.nodata(300)}=1
    ifInOctets.1.01 is the item name as you created it.
    Trigger is ON if there's been no new data over the last 300sec (SNMP polling failed for whatever reason).
    • Andrey123987456
      • Apr 2019
      • 44
      Good day to all! Help me please. I had a problem with the trigger, there is a network node, when it is working the trigger is normal, when it disappears from the network it signals the problem to me. {Obnaruhenie Mikrotik: icmppingsec.last ()} = 0. And I need to do that the trigger would not react immediately, but if the network node is not in the network for more than 5 hours. how to do it, I do not understand. I tried to play with count and nodata, but it doesn't work. Now I have come to this decision, but it also does not work correctly {Obnaruhenie Mikrotik: icmpping.max (18000)} = 0
