Problem Initializing zabbix
  • Davi_N
    • Nov 2004
    Hi. I followed the instruction on the Zabbix reference manual and I had some problems there.
    I have to say that I have no experience using Mysql. Nevertheless:
    1. after untaring the zabbix tar file It says I need to run the following commands:
    mysql -u<username> -p<password>
    Which username should I give? I've tried all my accounts (including root).
    2. When initializing Zabbix, I need to go to http://localhost/~zabbix i see the files and then I need to click on the config.php link and should get a screen that prompt me for user and password. Instead my browser (e.g. Mozilla) asks me where do I want to save the file (Save as...).
    I've installed all the requirments (Mysql, Apache etc'), running on Suse 9.1.
    Thanks.
  • riegersteve
    • Oct 2004
    • 68
    is mod php installed for apache if so make sure that the following line is in your apache config
    AddType application/x-httpd-php .php
    AddType application/x-httpd-php-source .phps
    also your mysql probably does not have a root passwd so do like this mysql -u root < path/to/zabbix/sql.sql
    without a passwd
