Performance when monitoring a big installation with Zabbix?
  • BumBum
    • Jan 2009
    Hallo
    We have a “simple” monitoring comparing current state (u/d) and values (error and utilization counters) with expected states. It also checks that expected values are received (reaction on for example disappearing interfaces) and it found current values have an expected value (reaction on new but overlooked/forgotten to enable items). We compare 30.000 items with an average of 5 parameters (u/d, counters) every minute. We want to replace our old self made monitoring with a new system and wonder if Zabbix do have the performance for that task?
    Gert and Gunnar
  • nelsonab
    • Sep 2006
    • 1233
    I feel that Zabbix can handle what you are looking to do.
    There are some things to consider when you're looking at Zabbix, the biggest of which is a core methodology. At the most basic level Zabbix will not tell you a yes or no if something is running. It will however tell you the quality of how something is running which in turn you can use to determine your yes or no value for something working. If you keep this in mind when designing your monitoring solution you will find it easier to design.
    If you have more questions feel free to ask away. :-)
    RHCE, author of zbxapi
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      I am not sure I fully understand this. Does it mean that you collect information from 30.000 items with the refresh rate of one minute per item? If so, it means that you must be able to process 500 new values per second, which is absolute possible with Zabbix. Consider using Proxy based approach if polling is heavily involved.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • BumBum
        • Jan 2009
        Thank you nelsonab and Alexei for your fast responses.
        One option which we still need is the SNMP Data with Dynamic Index. What do you think about the performance by our number of items.
        Gunnar
        • BumBum
          • Jan 2009
          For better understanding
          Dear Alexei,
          worse: 30.000 x 5 items
          Gunnar & Gert
          • rimestad
            • Jan 2009
            Question withdrawn
            Hi again,
            Test with Zabbix shows severe performance problems using dynamic indexes. The system will indeed, as stated in the manual, cause heavy load on the router monitored. We measured 100% cpu load on a cisco 2610 series monitoring 100 interfaces for ifOperStatus up. For us this is a knock out creteria, so we withdraw our question.
            Positive: We like the look and feel of Zabbix very much.
            Chers Gunnar and Gert.
            • Alexei
              Founder, CEO
              • Sep 2004
              • 5654
              Why worse, it is nice to see ZABBIX used for heavy computing! All right, it translates to 2500 of checks per second or 216M of new values per hour. This is still possible provided you have adequate hardware for the central server and you have no extreme requirements for storage of the collected data, i.e. detailed history will not be kept for years.
              Alexei Vladishev
              My Twitter
              • rimestad
                • Jan 2009
                SNMP dynamic lookup is the current problem.
                The server was a poor old pc but it had no problems. The router was the limitation due to massive snmp gets. Thus we believe the server could do it, but not our routers, which are for routing and not for snmp gets. What does it cost to get the snmp dynamic index problem fixed by tomorrow
                Gert and Gunnar
                • Alexei
                  Founder, CEO
                  • Sep 2004
                  • 5654
                  A poor old pc won't handle 2.5K of new values per second for sure. You need something better, much better!
                  Please send a message to us if you need a quote at http://www.zabbix.com/contact.php
                  Alexei Vladishev
                  My Twitter
