Which agent for RHEL AS 2.1 ?
  • tchjts1
    • May 2008
    • 1605
    Will the pre-compiled agent Linux 2.4.x work on RHEL 2.1 or do we need to do a compile?
    Thanks in advance.
    Jeff
  • nelsonab
    • Sep 2006
    • 1233
    Depends on a few things. Run the following:
    >rpm -qa | grep glibc
    >cat /etc/redhat-release
    >uname -a
    Feel free to sensor the hostname as appropriate, it's not important.
    RHCE, author of zbxapi
    • tchjts1
      • May 2008
      • 1605
      Hi Andrew -
      here's the results:
      [root]# rpm -qa | grep glibc
      glibc-common-2.2.4-32.25
      glibc-2.2.4-32.25
      glibc-devel-2.2.4-32.25
      [root]# cat /etc/redhat-release
      Red Hat Linux Advanced Server release 2.1AS (Pensacola)
      [root]# uname -a
      Linux server 2.4.9-e.71enterprise #1 SMP Thu Nov 23 11:44:38 EST 2006 i686 unknown
      • nelsonab
        • Sep 2006
        • 1233
        Grrr that does not help as much as I thought. My guess is that a RHEL 3 binary would work. RHEL 5 if memory serves me right is glibc 2.4.x and RHEL 4 is Glibc 2.3.x.
        Hope this helps get you closer. :-)
        • tchjts1
          • May 2008
          • 1605
          Appreciate the help.
          We'll try the 2.4.x precompiled agent. If that doesn't work, we'll compile.
