cisco template...
  • aprotector
    • Jul 2008
    • 27
    cisco template...
    I've been trying to setup a way to monitor all my switches (just a regular ping to find out if they're alive). However, I'm having a little trouble.
    I imported a template that looked like:
    <zabbix_export version="1.0" date="21.1.09" time="02.20">
    <hosts>
    <host name="Template_Cisco">
    <ip>0.0.0.0</ip>
    <port>10050</port>
    <status>3</status>
    <items>
    <item type="3" key="icmpping" value_type="3">
    <description>Ping Check</description>
    <delay>30</delay>
    <history>30</history>
    <trends>365</trends>
    <formula>1</formula>
    <snmp_community>itws</snmp_community>
    <snmp_oid>interfaces.ifTable.ifEntry.ifInOctets. 1</snmp_oid>
    <snmp_port>161</snmp_port>
    </item>
    </items>
    </host>
    </hosts>
    </zabbix_export>
    It seems to have created but when I create a new host and link it to that it doesn't seem to work. I'm just getting Monitored in green and then unknown in the Availability. Can anyone give me a little 'how to' to get it the rest of the way?
    Thanks.
