agent via proxy: availability: unknown
  • svenw
    • May 2008
    • 26
    why is it, that an zabbix agent that is monitored via some zabbbix poxy shows "availablitly: unknown" while i still get latest data from it.
    is that as intended or am i doing somethingwrong?
    regards,
    sven
  • xs-
    • Dec 2007
    • 393
    Availability is an column in the hosts table. Proxy updates do not update this column. (With distributed node updates its even worse).
    This could be fixed in the future (i hope).
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      I would recommend to always ignore the host availability. It is calculate for Zabbix agent and SNMP checks only and can be extremely misleading if external, active or any other checks are used.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
