Re-assign Web Scenario to Group/Host
  • Justin Freeman
    • Jan 2009
    • 18
    Hi
    Is there anyway to re-assign an existing Web Monitoring Scenario to another Group/Host?
    Currently, it seems that once this is created it cannot be changed. Would be great if this was made available on the Scenario page.
    Cheers!
  • xs-
    • Dec 2007
    • 393
    My guess is that the only way to do this now is a manual mutation in the db. Search the hostid for the host you with to have webcheck and enter that in the webscenario record you with to change.
