Notification problem
  • shion
    • Jan 2009
    today I have updated Zabbix to version 1.6.2, because the notification function doesn't work.
    I hoped this solve the problem but it's still existing.
    The notification function is broken after an older update from version 1.4.x to 1.6!
    But I don't know why, I haven't updated the system.
    I have a User which is a "ZABBIX Super Admin" as User type and he is dedicated to the group "test".
    As Media types there are Email, Jabber and SMS-Sender available.
    Furthermore existing a lot of items and triggers.
    Under the Configuration point Actions exists a Action, which sends the message "{TRIGGER.NAME}: {STATUS}" to the group "test". The Event source are Triggers. Status is enabled.
    If now occurs a problem, then the Trigger triggers and the Action which sends the messages to Jabber, E-Mail and SMS should be starting.
    If I look on the Monitoring-Dashboard website under the point Last issues, where you can see the current issues, then I see under Actions whats happens with the notification.
    User		    Detail		Status
    testuser	    Email		In Progress
    testuser	    Jabber		In Progress
    But it's always in progress.
    There is no message sent.
    I don't know where I can search for a solution or where I can find the problem.
    Have someone an idea?
    Best regards
    shion
  • shion
    • Jan 2009
    If someone has a little idea, write it please.
    Or if you need additional information, feel free to ask.
    • axel
      • Aug 2005
      • 36
      Same Problem with Jabber.
