Sending active checks to 2 servers
  • Neurotox
    • Nov 2008
    • 25
    In order to have redundancy in our monitoring we want to use 2 Zabbix servers on 2 different site.
    In Zabbix 1.6.x (an before) an agent can only send active checks to 1 server.
    I'm thinking about running 2 instances of the agent on each server with 2 different configuration file.
    Does any one have an another idea or any comment?
    Thanks,
    François
  • gazambuja
    • Oct 2008
    • 9
    me too
    i want do this, but 2 instances of same agent not sound good...
    any have a idea to do this?
    • Neurotox
      • Nov 2008
      • 25
      You can run 1 instance and use zabbix "passif" check or you can
      run 2 instances and use zabbix active check.
      Right now, I don't see any downside of using 2 agents except the fact that it using a little bit more resources but I think that is really negligible on any recent system.
      It's easy to configure 2 instances on Windows and on Linux, if you need help let me know.
      Of course, you could also modify the code of the agentd if you want
