Problems with trigger .last(#num) function
  • nms_user
    • Feb 2009
    • 43
    Hello all,
    I'm trying to use Zabbix' new (documentation tells since v1.6.2) trigger function .last(#num) which doesn't work for me.
    The triggers are defined as follows for example:
    ({ServerHost:net.tcp.port[{IPADDRESS},1433].last(#1)}=0) & ({ServerHost:net.tcp.port[{IPADDRESS},1433].last(#2)}=0) & ({ServerHost:net.tcp.port[{IPADDRESS},1433].last(#3)}=0)
    So this trigger should fire only if the last 3 checks were zero (0). But in reality the trigger fires when only one value changes to 0.
    Here the values:
    2009.Feb.03 15:05:13 Up (1)
    2009.Feb.03 15:04:43 Up (1)
    2009.Feb.03 15:04:13 Up (1)
    2009.Feb.03 15:03:43 Up (1)
    2009.Feb.03 15:03:14 Up (1)
    2009.Feb.03 15:02:45 Up (1)
    2009.Feb.03 15:02:13 Up (1)
    2009.Feb.03 15:01:43 Down (0) <-- Trigger fires!
    2009.Feb.03 15:01:13 Up (1)
    2009.Feb.03 15:00:43 Up (1)
    2009.Feb.03 15:00:14 Up (1)
    Anything I've understood/done wrong? Of course we are on v1.6.2...
  • Calimero
    • Nov 2006
    • 481
    .last() ignores the argument it's given. It will only return/evaluate the last value.
    You should try the "aggregate" functions like min/max/avg/count.
    You could for example use something like that:
    host:net.tcp.port[,1433].count(#3,1)=0
    which reads "if the number of '1' I got over the last three checks is ... 0" (ie: last three check all returned 0).
    You could also use .max(#3)=0 meaning "the maximum value over the last three checks is 0 (ie: all checks returned 0)".
    PS: Be careful with 'simple checks', some of them return 0 or 2 (timeout) in case of failure so min/max is probably not really a good idea.
    • radamand
      • Aug 2008
      • 89
      I can't get this to save-
      {myserver:web.test.rspcode[myserver,Login].count(#2,200)}=0
      (reading: "if the number of '200' i get over the last 2 checks is .. 0")
      This is a trigger from a web scenario, I want to trip the trigger if the last 2 tests did not result in a "200".
      When I save this I get "ERROR: Cannot update trigger".
      • Andreas Bollhalder
        • Apr 2007
        • 144
        How about:
        {myserver:web.test.rspcode[myserver,Login].count(#2,200,eq)}=0
        As far I remember, you need at minimum 1.6 to work with this.
        Andreas
        Zabbix statistics
        Total hosts: 380 - Total items: 12190 - Total triggers: 4530 - Required server performance: 224.2
        • nms_user
          • Feb 2009
          • 43
          @Calimero:
          Thanks for the answer.
          Yes, i know about the "old" behaviour of .last() that it will return only the last polled value.
          But i was really happy by reading the documentation Rev. 017 (for v1.6.2) where page 126 tells me:
          last: Last (most recent) value. Parameter:
          #num – Nth value
          For example,
          last(0) is always equal to last(#1)
          last(#3) – third most recent value
          Parameter #num is supported
          starting from ZABBIX 1.6.2.
          So where's the problem - wrong documentation / wrong trigger-definition / wrong understanding of mine / ?
          Re: PS: The trigger isn't based on a simple check, its item is "Zabbix Agent" with net.tcp.port (which indeed is a simple port check, yes...)
          • Calimero
            • Nov 2006
            • 481
            nms_user, I'm still running 1.6.1 (and working with an even older manual ) that's why I didn't now of the improved last() function.
            Anyway, as I understand if, last() will still evaluate a single value but instead of giving you the very last you can now fetch value N, N-1, N-2... N-# ... but it will only evaluate a single value.
            I think .min() or .count() is still the way to go or of course you could now write:
            {host.key.last(#1)=0}&{host.key.last(#2)=0}&{host. key.last(#3)=0}
            to check that the last 3 checks failed.
            radamand >
            The syntax .count(#42,whatever) is new to zabbix 1.6: count the number of 'whatever' occurrences over the last 42 checks.
            If you're still running 1.4, only .count(600,whatever) is supported: count the number of 'whatever' occurrences over the last 600 seconds.
