on my windowsXP box I try to define trigger for "Low free disk space on {HOSTNAME} volume c:" from Windows Template.
Why the trigger fire out in trigger status page with status "OK" and green colour although the trigger settings are met?
Trigger expression: {hostX:vfs.fs.size[c:,free].last(0)}<95000000
Severity: Averadge
Event generation: Normal
What trigger status means? I can see 3 different status: OK, Problem, Unknown.
Why trigger filter set to: "Show only problem" doesn't work? - I still can see triggers with status "OK".
Regards
grejer
Severity: Averadge
Regards
grejer
