conditional expression in action messages
  • fege
    • Dec 2008
    • 34
    How I can use conditional expression in action messages?
    I try this
    if status = ON send message PROBLEM
    else
    send message PROBLEM SOLVED
  • xs-
    • Dec 2007
    • 393
    You might want to look at recovery messages
    (keep in mind that you must use the condition STATUS=PROBLEM for this or else it will just send a normal message instead of the recovery).
    There is a good howto of this in the cookbook section.
