Process Monitoring: Send & Receive Email
  • bytesize
    • Aug 2005
    • 71
    Hi guys,
    I was wondering if anyone has managed to monitor the entire process of email sending and delivery with Zabbix?
    I have a QMail / Vpopmail linux mailserver with both SMTP and POP on the same server. I have simple checks running to make sure the services are up, but I still don't know if something like SpamAssassin dies and maildelivery is not happening.
    Would it be possible to send an email to a mailbox on the server, then get Zabbix to check it arrives? Does anyone have any better thoughts on monitoring this process?
    Thanks in advance!
    John
  • elkor
    • Jul 2005
    • 299
    well you could see if the process is running simply by checking the list for it and have zabbix check for it as a userparameter
    i.e. ps -ef | grep -v grep | grep spamassasin | wc -l
    would return a nonzero reply if it were running.
    or... you could also just use proc_cnt[spamassasin] ;-)
    personally I would write a script that counted items in the various queue directories and dumped those values to a status file; then set up a userparameter(s) that parses that file. That way you also gain historical information about queue size etc and you can set a trigger if there are too many items in the queue.
    • infinity
      • May 2005
      Check on email return
      Hi There
      This is similar to the same check, however we want to check that an email is received.
      We have a system where an automatic response is returned on each mail that is received. We want to have a check that will know if the automated email is received or not.
      Any ideas?
      Cheers
      • richardh
        • Dec 2005
        Hi John,
        I have 3 perl scripts being run by CRON, one to send an email, the second script connects via POP3 and counts the emails and outputs to a text file and the third deletes the mail... though they run in the reverse order...
        Now I'm just trying to set up the vfs.file.regmatch to check for the count in the text file
        Hope this helps
